H guys,
I’m actually creating a lightshow that’s of course triggered by music. I’m using the latest official release 4.12.2 and a USB DMX 4 ALL MKII Dongle.
My Problem: I’ve often to jump back and forward in the music track (length appr. 43minutes) When I start the show from the very beginning the lights a reacting on time but minute after minute I got a bigger delay between the light signal (reaction) and the music witch is a complete mix of 43min. when I jump a bit backwards to set a light scene and play from the last position than its fine but when I start the show from 0:00 the delay is back. Is this a bug or do I something wrong?
Thanks for ur input
Ciao Stevo
Music delay whie programing a show
- StevoLight
- Real Name: Stevo
Ciao Stevo
- StevoLight
- Real Name: Stevo
Till I get no response but i need to fix that issue because a show is complete senseless if its no fit with the sound.
Massimo I attached the QXW file and hope you can help. Meanwhile I updated the driver of my soundcard but this is also not the problem but good to know that my running system is up to date to eleminate further problem issues. It seems to be that the actal integrated musicplayer in QLC is not the best one.
Further I recomend to fix the timline and the zoom-fader at the window that I dont have to scroll. Only the different sequences should be to scroll.
Also a possibility to enter the exact time with the function that the play-curser has to jump to this time.
Grazie mille
Grazie mille
DMX Show DiveIn.qxw
- qlc show
- (221.31 KiB) Downloaded 164 times
Ciao Stevo
- StevoLight
- Real Name: Stevo
It seems more and more that my music track is to long with 43min. In this screenshot u see the visualization broke up and when u see obviusely silence I listen music. So I order all light scenes by the music but everytime I play the show that doesnt fit. What also my be an issue is after zoom in and out the time of the Music and Lightscenes are more divverent. this might be also a bug.
Its actually hard to find a solution for me!
Please Help!
Please Help!
Ciao Stevo
Hi, your questions seem to be QLC+ 4 Issue reports. You may find more answers there.
- StevoLight
- Real Name: Stevo
Thank u Nils for the first and only reaction on my issue!
Ciao Stevo
