I want test the latest build but in https://software.opensuse.org/download. ... us-qt5-git all the version are 4.12.1.20181216 and 4.12.1.20181111 for archlinux.
QLC+ TEST versions
Arch builds should be fixed nownozof wrote: ↑Fri Dec 21, 2018 10:10 am I want test the latest build but in https://software.opensuse.org/download. ... us-qt5-git all the version are 4.12.1.20181216 and 4.12.1.20181111 for archlinux.
- Real Name: philippe GATT
Whatever version 4.12 the module controls plant and does not open.
Macbook pro Core 2 duo 2,53 Ghz 8 Go DDR 3
- lorenzoandreani
- Real Name: Lorenzo Andreani
Windows 10
QLC+_4.12.2.30.exe
Artnet Fixture in LTP mode:
- a button linked to scene set the channel 1 to 255
- a Slider in Level Mode is linked to channel 1
- in Live Mode slider work
- Activate the Button (so the channel 1 go to 255)
- But slider does not work anymore
QLC+_4.12.2.30.exe
ArtNet.qxw
- (4.16 KiB) Downloaded 2692 times
- edogawa
- Real Name: Edgar Aichinger
I'm not Massimo, but the initial post of this thread has all the links for test versions, and even tells the date for the Windows build:
Looking at the version numbers of the filenames in that linked page, it seems obvious what the latest version is, 4.12.4.158
Windows: Automated builds (updated: 2021-02-26)
The last number of Windows test builds is incremental. So the higher, the latest
The links for windows and mac test builds are broken. Pls fix.
Confirmed
If you take the libharfbuzz-0.dll file from 4.12.4 it will work.
Basically a library changed in the meantime and Qt broke miserably.
thx, grazie, I take this opportunity for another question, I am using an old thinkpad is it possible that using the EFX function with the pre-installed movements the lights move in jerks? depends on the power of the pc? minimum configuration required?mcallegari wrote: ↑Fri Jul 16, 2021 11:37 am Confirmed
Please try the 4.12.5.13 version. I had to rebuild Qt with the updated environment.
Please let me know if it works now
@Tsurugi this is not the right place to ask for support. Please open a new thread in the proper area otherwise this thread will become a mess
- edogawa
I'm sorry Massimo, but here the .13 test build doesn't work under Win10 1909.It installs but when trying to run it shows attached error box immediately, translating to:
Procedure entry point"_ZdaPv" not found in DLL "..."
The 4.12.4 install works perfectly on the same system.
I'm a linux user normally, just by chance I booted to Win10 today to do some OS and app updates, and stumbled upon this.
(I'm trying to run a 20h2 update right now after it failed a month ago...)
- QLC+4.12.5.13-error.PNG (7.48 KiB) Viewed 135799 times
Please try the latest version available.
I built it with my PC. This should definitely work.
