I want to put a normal frame in a solo frame. So I can use more faders in the normal frame, but when I push a button in the solo frame, all the faders inside the normal frame (which is inside the solo frame) will turn off.
But now, when I put a normal frame inside a solo frame, the faders in the normal frame act like in the solo frame. I can still open only one fader and the other will turn off.
Is it possible to let all the items in the normal frame act like they are in a normal frame, but when I push a button outside the normal frame, but inside the solo frame, all the faders/buttons in the normal frame will turn off?
So it's like you have two groups of normal frames inside a solo frame. So when I change somethings inside group-1 and then change things inside group-2, group-1 will reset. Like normal buttons in a solo frame.
Normal frame in solo frame
- Real Name: Robin
Here the workspace...
- Normal frame inside solo frame.qxw
- (6.13 KiB) Downloaded 79 times
- Real Name: Peter Baumgartner
I don't know what you did exactly, I tried your qxw on my 4.10.4 Linux, and it worked as exoected:
The "purple" button raises the red and blue faders.
What system and version do you have?
Peter
Peter
