[SOLVED] Usage of RGB matrices and chasers
The_Onipel
Hi everyone !
I'm using QLight+ for few months and I'm trying to improve my presets. English is not my native language so I hope I'll be comprehensible ^^.
I created RGB matrices with 4 LED xBrick bar. I would like to launch animation on those matrices but with the ability to change colors. I tried to use masks and I read the documentation about "RGB Matrix Blending" unsuccessfully.
My first idea was to create a chaser with scenes that are only modifying colors as animations are still running but when I tried, it has completely destroyed animations.
I tried many different things but nothing really worked.
Could someone help me or give me a hint ?
Any help would be appreciated,
Thank you very much !
Please attach your workspace (.qxw) File here.
The_Onipel
Hi, thanks for the answer.
Here is the file, I've done my best to make it clear enough :).
Forum Help (The_Onipel).qxw
(12.12 KiB) Downloaded 63 times
I tried a second method, a bit closer than what I'm trying to do, I called it "Test n°2 - With sequences". The problem is now that flashs are sometimes appearing and I don't know why.
If you have difficulties to understand the problem with the 3D Viewer, I upluoaded two small videos with the live LED bars.
Test n°1 : https://youtu.be/Gq_fCMChioc (Animations stops when a new color change scene is activated by the chaser)
Test n°2 : https://youtu.be/n8Rt_d1PWwA (Flashs are occuring with no reasons when colour change)
Thank you :)
The_Onipel
After few hours of attemps, I finally decided to do it in an other way without chasers.
Thanks anyway !
Topic marked as SOLVED.
