Hey sorry about my worse english
i'm trying to make a websocket connection to qlc
its works whit ws:// but i want the connection be more secure whit wss:// is that posible
i cant get it to work
kind regardz
Laurijn
Websocket
Hi, i think you should modify the source code to pick up some SSL certificate.
Please let us know if you succeed in doing that.
- Real Name: Mr Mike
If encrypted websockets are necessary for you, then your options are adding that functionality to the QLC+ code, I'm sure Massimo will appreciate the help making that happen. Or you could use something like nginx in front of QLC+ to handle the TLS/SSL communication, and proxy the traffic back to QLC+ for you. See:
https://stackoverflow.com/questions/121 ... s#14969925
http://nginx.org/en/docs/http/websocket.html
http://nginx.org/en/docs/http/configuri ... rvers.html
for more info
for more info
