Artnet or 1.31 Manual IP Address
The IP-address is choosen by your O.S.
Per default Artnet uses 2.x.y.z netmask 255.0.0.0 - so if you want to be Artnet conform you have to set a fixed address in the 2.x.y.z range in your O.S.
e1.31 is sACN (streaming ACN) runs on top of network so the exact IP-address doesn't matter (as long as all participants are in the same range f.I. 192.168.1.x netmask 255.255.255.0)
What do you want to 'unlock'?
