Hi everyone!
I have on Virtual Console some Solo Frames and some Cue Lists assigned to MIDI notes but when i im using a Scene inside a Solo Frame and than i select by MIDI a Cue list, the Scene selected on Solo Frame didnt stop! it mixes with the Cue List .... and also the inverse situatuation.... is there any way to do this ?
I would like to select one at time only not mix them.... example C2 Solo Frame Button 1 , C#2 Scene 1 and so on but they must stop each other when selected....!???
Best regards,
Ruifa
Solo Frame + Cue List
- Real Name: Lukas
As the online documentation states, a solo frame will only work with buttons.
I don't know if what you want to do is possible at the moment.
- Real Name: Ruifa
Hi Siegmund! thank you gor your reply,
I wonder if there´s any way to do the same but with CHASERS...? whayt i need is to select a Chaser and than onother one but that when pressing the other it will disable the previous one and so on
If you know please let me know!
Best regards.
Ruifa
Best regards.
Ruifa
- Real Name: Lukas
I got what you want to achieve and already thought about how to do it but with no results. You could use buttons controlling loopback channels to start the chaser but the chaser will not stop when deactivating the button.
Actually I think the documentation needs some love in that area.As the online documentation states, a solo frame will only work with buttons.
If I remember correctly, Cue Lists and Audio Triggers are also included in the Solo Frame exclusive behaviour
