Hi everyone,
I used to work with QLC 4.12.3 on Windows. I changed for 4.12.6 and i recently notice a little change on cuelist widget. I use it for theater, with "Hold" in infinite. I don't know if it is wanted or not :
Before, while the playback was already launch, i was able to select a cue anywhere in the playlist, and start it just by clicking pause, then play.
I always use Play/Pause + Stop, so i just have to press twice the same button.
Now, it don't work anymore. The number on the crossfader change, but the scene is not launch.
I need to click on Stop first (shut down of lights), then Play to get the scene i want on stage.
Maybe I missed something ?
PS: I notice it's stil talking about two faders for crossfade here : https://www.qlcplus.org/docs/html_en_EN/vccuelist.html
Cuelist - Select and play a cue after pause
- Real Name: Paul Misset
- Real Name: Ken Coughlin
All I have ever had to do is single click the cue (step) I want to jump to, to set focus to that cue, the press the enter key. I have been doing this for years, on many different versions. It doesn't matter if the Chase is stopped or running another cue.
I just wanted to make sure you're following the same steps as me.
- Real Name: David Gouronc
No , i talked about play/pause button on widget, and something changed here.kenact wrote: ↑Thu Nov 03, 2022 2:23 pmAll I have ever had to do is single click the cue (step) I want to jump to, to set focus to that cue, the press the enter key. I have been doing this for years, on many different versions. It doesn't matter if the Chase is stopped or running another cue.
Anyhow, you give me a good solution. I never used Enter key before, and it works very well, even in last version. Thank you for the trick.
