This may be a silly question but I have looked all over for the answer to this. I also read the manual.
I cannot get my scenes to snap to grid. With the grid activated- it shows the grid lines but does not automatically drop the element to the nearest gridline. I have tried this in Windows and Linux and this behaves in the same way on both OS's. I am hoping I am missing something really obvious and hope this question is an easy fix but not too annoying.
Also, if I can resolve that... is there a way to stretch out an element (scene) without typing a longer time frame? And can I copy multiple elements in QLC+?
That is all of my annoying questions for now.
Thanks in advance for all your help!!
Snap to Grid
- Real Name: Ken Coughlin
"is there a way to stretch out an element (scene) without typing a longer time frame? And can I copy multiple elements in QLC+?"
I don't think there's a way to stretch a scene, without using the speed dial window. You can copy multiple elements, but you have to copy them one at a time.
Once you select the scene and get into the chaser window, you can copy as many sequences as you've created, or paste a sequence multiple times. Typically, I'll add a scene to a show, that has all the fixtures I plan to use for that show. I will then copy and paste that scene as many times as I need, setting fade-in, fade-out, duration and fixture intensity for each iteration.
