I found this bug that I define as critical
qlc+ 4.11.2.89 OS w10
as you can see in attached workspace if you go from scene 1 to 2 the value of scene 1 DON'T go to 0 instantly but follow the fade in time of the next scene. This is a very big issue if you whant to create asymmetrical crossfading between scenes, there is a workaround indoducing senes in between, but is a bit a pain if you have a lot of scenes as usually i have in theatre.
Major issue in chaser
- Real Name: Iro Suraci
- bug chaser fade time.qxw
- (2.55 KiB) Downloaded 80 times
ok, i have not seen a previous post about same topic
- Real Name: Mark Lohrey
Hi Maximortal,
There are many issues associated with fades in cues that seem to affect theatre operators more than others. I am sure Massimo is aware of them and QLC+5 will have solved the problems.
Anyway, a simple work around to your problem is to disable the channel of dimmer #1 in scene two.
Cheers
Mark
Cheers
Mark
ok thanks for the tip
