Using External Midi to program
Welcome,
As you are not asking specific questions: Yes you can.
Did you check the tutorial? http://www.qlcplus.org/docs/tutorial-bcf-lc2412.html
Regards,
Regards,
If the question is whether faders in Scene Editor are externally controllable then the answer is no.
It looks like you may use Channel Groups: http://www.qlcplus.org/docs/channelsgroupeditor.html
I've never used them myself, so I can't comment, but it looks like you can assign external control to them and they work in Function editor.
Check Massimo's tutorial #2: and tutorial #4
