Hi there
I'm looking for a possibility to fire a script at the time when a page is changed inside a frame.
Background : I have a midi controller with LCD strips above the faders. I wrote a bash script, which issues the necessary midi command via sendmidi to write the necessary text to the lcd. The bash script is called by the systemcommand inside a qlc+ script.
Any idea to trigger the qlc+ script when changing the page inside a frame ?
Thanks & Greetings Matthias
Auto script when change page in frame
If you use a loopback button to change the page, you can create a Collection with the Scene/Sequence that skips the page and your Bash Script (or also call that Sequence from your QLC+ script).
For an example look overhere: https://www.qlcplus.org/forum/viewtopic ... 234#p70234
