QLC+ 4.13.2-GIT Qt6 crash playing audio track in show
sbenejam
QLC+ 4.13.2-GIT on Ubuntu 24.04 with Qt6.8.0
  • Create a Show with an audio track and add an audio file to this track.
  • Play the show directly from Show Manager or from a VC button when the show reaches the end of the audio file QLC+ crashes.
  • Tested with mp3, wav and ogg audio files crashing in all cases.
  • A track in a show with a video file not crashes when reaching the end of video file.
  • Playing an Audio File with a button in the VC QLC+ not crashes at the end of audio file.
  • Audio files in Cue List playing as expected too.
QLC+ 4.13.2-GIT on Ubuntu 24.04 with Qt5
All works as expected
Function start(). Name: "Audio2" ID:  6 source: 4294967295 0 , startTime: 4080
Function preRun. Name: "Audio2" ID: 6 type: "Show"
Ordered list of ShowFunctions (time):
[Show] Function ID: 8 start time: 3360 duration: 2480
[Show] Function ID: 9 start time: 6660 duration: 2948
Ordered list of ShowFunctions (beats):
ShowRunner created
void ShowRunner::adjustIntensity(qreal, Track*) Track ID:  0 , val: 1
ShowRunner started
"doorbell9.wav" Override requested for new attribute 0 value 1 new ID 128
Function start(). Name: "doorbell9.wav" ID:  8 source: 0 6 , startTime: 720
Function preRun. Name: "doorbell9.wav" ID: 8 type: "Audio"
Creating audio sink on "TOZO-T6"
Function stop(). Name: "doorbell9.wav" ID:  8 source: 0 6
Function postRun. Name: "doorbell9.wav" ID:  8
void Function::resetElapsed()
Time is late by 173845933 nanoseconds
virtual void MasterTimerPrivate::run() MasterTimer is running late!
I can confirm this one. I'll need a bit to fix it.
Thank for reporting
sbenejam
I just tested again this issue with the latest version of QLC+-4.14.1-GIT and Qt6.8.2 on Ubuntu 24.04. I have found a temporary solution, just configure the playback mode of every track to Loop. Upon reaching the end of the track, QLC+ does not crash and the next track is played as expected.
Hi Santiago, should be fixed now. Please check
sbenejam
Hi Massimo, good news. I'll check it later.
sbenejam
Massimo, works as expected now.
Great, thanks for testing
