Been using QLC a lot and I usually use the virtual console for shows and it works great all the time. Thank you for making this software!
This is my first time using the show manager view properly and it worked great for a few days, but has now started freezing for at least a few minutes after every action (scrolling along timeline, switching to and from the tab, Selecting EFX channels or sequences)
My most recent addition is adding EFX for fusion 120 Zooms and a sequence for the Chauvet colorband Pix-m USB's.
The file works absolutely fine in all sections of the app apart from the show manager tab.
Core i7-1250U 10Core 4.7GHz
16gb DDR4 RAM
512gb NVME SSD.
I've attached the file. I use some custom fixtures so not sure if I need to attach those too. The song is in track 1 but I'm not able to attach it here as it's too large.
Constant freezing in the Show manager view
EPQ number 2 electric booglaoo (wahoo).qxw
- Ignore the name lol
- (92.78 KiB) Downloaded 211 times
Do you have functions with infinite duration?
That's really bad stuff for the show manager
Changed the EFX functions to 3mins and seemed to fix it so thank you!mcallegari wrote: ↑Fri May 05, 2023 6:45 am Do you have functions with infinite duration?
