shows manager stop without reason
interval
Hello, I have a bug very difficult to reproduce, it happends to me a couple of time and become now very serious for the use.
We are using it for a band in live shows.
on windows 10 using QLC 4.2.4 and extensively use the shows manager to sync backtrack/clic with lights
For some reason, the shows just stop when reahcing some of the steps. This is really random,
Let's say I have one chaser name "all white", which puts all dimmer white lights on
It use to work in all shows, and for some reaosn, when laucnhing the show, it will stop in all the one that use "all white" when it reach it.
It only happens when you are in "operate mode"
Here is a video
and my file:
interval qlc 4.qxw
(110.48 KiB) Downloaded 160 times
it persists when shuting down/restarting the app.
I tested the project from another laptop with a QLC 4.2.4 on it, same behaviour...
The workaround I found is is to delete the chaser (or whatever function it is) and recreate it, then reassign it in all the shows. YOu can imagine this is absolutely not reliable when you have 30 shows using the item.
That's really anoying and prevents from using for production, is there any chance you look to that, I can provide all necessary details if needed,
Thanks a lot
