Numbering of Playback sliders
The issues found when using the Simple Desk panel
jpearson0525
Real Name: James Pearson
The number of the Cue Stack playback sliders has two # 15 sliders.
Version 4.12.2, Raspbian Buster based on Raspberry Pi 3 B+.
JIm.
kenact
Real Name: Ken Coughlin
t does in Windows too.
edogawa
Real Name: Edgar Aichinger
I think I found where in the code that happens, it's just an issue with displaying, internal numbering is ok.
I just recompiled an it displays correctly now. Before, at resizing the window, the doubled number always appeared when a new playback slider got added, that led me to looking for resize code.
I don't have time today to make a proper Github pull request, but as it's such a trivial change, maybe @Massimo can you just pick it up from here please?
ui/src/simpledesk.cpp, line 1681 should add 1 to the slider count.
                slider->setLabel(QString::number(m_playbackSliders.count()));
should be changed to
                slider->setLabel(QString::number(m_playbackSliders.count()+1));
Sure, I'll have a look at this maybe later today.
Thanks for reporting
[EDIT] just pushed upstream
