I downloaded the most recent version of QLC+ onto my Win 7 Pro desktop and am using a brand new Enttec open dmx USB. With this setup EVERYTHING works perfectly! Then I install the same version of QLC+ and the Enttec drivers (from their site) on my Windows 8.1 laptop and there is some control of fixtures, but every light flashes constantly with random frequency.
I figured the laptop was a bit older so I tried the same install on my Win 10 developer laptop and had the same strobing issues. Plug the Enttec back into my desktop and everything works fine again.
So I've tried to: use different cables (all DMX) and terminators, one light at a time - and I tried all the different models I have, powered USB hubs, I've edited the registry to change master refresh rates/limit DMX output channels, rates on the Enttec itself, device driver settings for the USB devices, Windows power profile settings, you name it, all to the same result. I also have the same issue using FreeStyler.
Here's a clue that may help - I installed Martin (now Onyx) M-PC last night on the offending laptop using the same lighting setup and Enttec, and everything worked fine. Fire up QLC+ and the flickering resumes. I also tried some simple DMX controller software on that laptop that also works fine using single lights.
So I've ruled out: The lights, cables, Enttec, and the laptop. As a software developer the only thing I can see remaining as an issue would be the way QLC+ (and FreeStyler) is passing data packets to the FDI driver but only on my laptops. Maybe parts of the packets are getting lost causing them be addressed incorrectly? Or maybe complete packets are being lost? For example I can bring up the master dimmer, then the red channel on a fixture and the red will light but will flicker even with the strobe setting to steady light. Any ideas would be greatly appreciated since I've spent quite a bit of time developing my show in QLC+ on the desktop but just can't cart it around to our band's gigs
