Yiflamefly Beam 450W Moving Head Lights
gsekkesater
Real Name: Geir Sekkeseter
Hope it works. Haven't tried it yet.
Beam-moving-head-lights-450W.qxf
(7.01 KiB) Downloaded 59 times
MichelSliepenbeek
Real Name: Michel Sliepenbeek
I'm sorry, it will not work. :evil:
If you use the Fixture Definition On Line Validator (https://www.qlcplus.org/fixture_validator.php) you will find:
ERROR: channel <Strobe> group should be set to 'Shutter'
ERROR: channel <Colorful> capability with empty description. Please write one.
ERROR: channel <Frost> capability with empty description. Please write one.
ERROR: channel <PAN fine> control byte should be set to Fine (LSB)
ERROR: channel <TILT fine> control byte should be set to Fine (LSB)
ERROR: channel <Reset> capability with empty description. Please write one.
ERROR: channel <Lamp open> capability with empty description. Please write one.
ERROR: channel <Led strips speed> group should be set to 'Speed'
ERROR: no modes found in this definition! Please define some.
Furthermore you need to change the Type of your "Lamp Open" channel (to Maintenance ?).
As it is Intensity now, it will override your Dimmer Channel.
It is very strange that you use the Channel Number as Default Value for a Channel?
This does not make sense.
gsekkesater
Thanks a lot for your reply. Its my first time trying out this. I will do the changes you suggest.
