Hi there,
i posted this bug allready, but now i can reproduce it. Its not a big deal (i think), its only a visual problem. Steps to reprocuce
1. Load work attached work space
2. look at the only show in it (in show mode)
3. there are only 1 track in it with 2 sequences
4. the second sequence named "One Step" looks like it has 2 steps, but it has only 1
The problem occures if the sum of all hold times is smaller than 1s! The first sequence (named "4 Steps") has 4 steps with 300ms per step, so it has 1200ms overall length, so the bug isnt visible here! If you add more sequences with a overall hold-time unter 1s, this will look like 2 steps too!
This bug isnt a problem, but its confusing while programming
Used QLC+ 4.12.2 on windows 7
Hope i can help a little bit with making bugs reproduceable...
Best regards
CoS
visual bug (one step looks like 2)
- onestep_error.qxw
- (3.84 KiB) Downloaded 263 times
- Real Name: Mark Z
I believe this is intentional
If you have a very short function on the show timeline, it will be impossible to see.... so even though it appears to be longer on the timeline, it is still the correct length when it plays.
Not a bug. Intentional. Imagine if you had a 20ms sequence... you'd never be able to click or see it again!
