Hello all,
I'm in the process of moving my tests to the RaspBerry Pi (instead of my macs)
I downloaded the latest 4.12.2 from the reserved web area, but I'm facing some issues:
- Whenever I connect "locally" to 127.0.0.1 with the Web-API-test, I can connect, no matter if QLCPlus runs or not !!!
- The values that I set with "Simple Desk channel set", can be read back with the "GetChannelsValues".
However, I don't see the sliders move in Simple Desk. (this works fine on a mac)
- When I try to connect to the RPI from a Mac (with the Web API test), I doesn't connect.
I can ping the machines in both directions,so network connection is OK !
- I tried running QLC+ on the RPI with and without the --web at the end, doesn't change the situation.
I'm lost with this one, I must be missing something
Any help is appreciated
best regards from Belgium,
Kris
Issue with Web API and RPI 4 (Debian Buster 27.05.2020)
Hallo Kris,
You have to make sure that the QLC+ instance is bound to the 'outside' network interface. (Hence not 127.0.0.1)
This is to make sure that the port QLC+ uses, is touchable from outside.
Sliders moving in Simple Desk ... as a result of setting them from the API? Is not meant to be working in real-time (?? !!)
Simple Desk is more like a test-mode desk and in production, the focus goes to Virtual Desk.
Groetjes,
Groetjes,
- Real Name: Kris Wauters
Well, the problem is (was) not network related
On RPI, a service QLC+ is running, and this service does not communicate with a desktop instance of QLC+.
(that's why setting variables via the web-api, do not reflect in the desktop instance, and visa versa, and I could connect to the local webinterface, even when the desktop instance of QLC+ was not running)
Furthermore, there is an issue with websocket in FireFox 79.0 (64 bit- on MacOS Catalina 10.15.6. - the websocket seems not to be able to connect !
I used my own piece of software (that I wrote in Python, to make communication possible between an Elgato Stream Deck XL (without official Elgato software, connected to a RPI3) and QLC+ (running on a RPI4))
In the meanwhile, I fixed my own problem
As a temporary solution (proof-of-concept):
1. I stopped the service with:
2. I started QLC+ with:
This resulted in the same behaviour as on my mac machines, when I did set something via the web-api,
this changes where immediately reflected in the desktop instance of QLC+
Because I'm going to use this RPI4 mostly with QLC+ (+running a few tasks in the background, so I can't use the full qlcplus RPI image),
and I want QLC+ to startup after boot, fullscreen, with my "musicstudio" workspace loaded, I did fix the permanently:
Permanent fix:
1. In the folder /etc/init.d I renamed qlcplus to qlc+.bak:
I also did take away the execute rights of this file:
This prevents the QLC+ service from starting af boot time.
2. Next, I created a qlcplus.desktop file in /home/pi/.config/autostart
In case the autostart folder does not exists (yet):
4. Make the qlcplus.desktop file:
5. Next, insert the following data in this file:
6. save the file, exist it, and reboot ...
7. Eeh voila, QLC+ starts after reboot, running fullscreen, with an accesible web-interface that is attached to the desktop version of QLC+, and running my musicstudio workspace
(behaving exactly the same as on my mac machines)
I don't know if this is the correct way (I'm a mac user and windows developer by default), but it works for me.
Maybe somebody can explain what the qlcplus service is actually for ? It doesn't communicate with the desktop instance of QLC+ !
Next step for me: creating all my fixtures and create scenes. (to be activated via the web-api)
best regards,
Kris
sudo service qlcplus stop
qlcplus -w
Permanent fix:
sudo mv qpcplus qlc+.bak
sudo chmod -x qlc+.bak
mkdir /home/pi/.config/autostart
nano /home/pi/.config/autostart/qlcplus.desktop
[Desktop Entry]
Type=Application
Name=QLCplus
Exec=/usr/bin/qlcplus -w -f -o /home/pi/musicstudio.qxw
best regards,
Kris
