Edit in QLC+5 and Run on QLC+4
Ask a question related to the QLC+ 5.x usage here.
Provide as much details as you can, especially what you would like to achieve and if available, a sample workspace of your work in progress
Kreepaul
Real Name: Paolo Ciscato
Hello
I've just installed (in a different directory) QLC+5
I tested the show manager and is way powerful than V4.
So question is:
Can I use Show Manager V5, and then run the saved project with V4?
I have try to open the V4 project with V5 (works), open the V5 project on V4 (works), so seems that answer is yes.
Someone can confirm?
Paolo
v5 projects on v4 are not guranteed to work.
If you stick to the show manager only...maybe
If you start using 3D view and palettes, I don't think so
Kreepaul
Thanks, will do some test to see what happen using new functions.
thestreets
Real Name: Rockband The Streets
Hi Kreepaul,
Have you tested this?
I need a bit more show functionality that I have seen in the QLC5 version also.
THNX.
