Manual:
https://images.static-thomann.de/pics/a ... _pl_it.pdf
These are both covered by the same manual so I did both.
I've selected Type: “Colour Changer” for the TS 40 WW even though it only has Warm White, perhaps it should be Other? It's not just a dimmer. Or is it?
Cameo TS 40 WW & TS 60 RGBW
- Cameo-TS-60-RGBW.qxf
- (6.94 KiB) Downloaded 139 times
- Cameo-TS-40-WW.qxf
- (2.96 KiB) Downloaded 126 times
Both added, thanks.
Not quite sure what to do with the beam range, since apparently it cannot be controlled via DMX ?
QLC+ will pick by default the lower, which might not look right.
