Hi everyone,
I would like to create definition file for Excelighting Color Spot NS 530 but I was unable to find channel documention.
Please, could you help me ?
If you got definition file, it is OK for me...
- Real Name: Patrick Yoyotte
Didou
OS: Ubuntu 18.04 Mate Edition
QLC+ Version: 4.12.0
- titigab
- Real Name: Etienne
Here is a definition I just made based on the fixture file for Sunlite Suite 2 (no ref anywhere else on the internet, not even on constructor website).
May not be correct...
- Excelighting-Color-Spot-NS-530.qxf
- (6.5 KiB) Downloaded 92 times
Many thanks, titigab.
I will test it and let you know.
Regards,
Regards,
Didou
Hi titigab,
I contacted Execlighting support and they told me Color Spot NS 530 is a clone of GENY OBY 5.
Here: http://www.techni-lux.com/default.aspx?tabid=13&id=639
OBY5 fixture definition is already present in QLC but it could be improved (4 different modes instead of 1 in current definition file).
See documentation here https://www.dropbox.com/s/ozlvnnerqi4u5 ... 5.pdf?dl=0.
I put it on Dropboxi as it is too big to attach it into message.
I'll try to post an updated one if I can find some time in my busy agenda...
Regards,
Regards,
Didou
Here is updated version I corrected channels and modes based on documentation I posted earlier.
Hope this helps.
Regards,
Hope this helps.
Regards,
Didou
I also create an updated version of Geni OBY 5. See below
Didou
- Real Name: Lukas
Thank you for sharing!
I adjusted some capitalizations in both definition files.
@massimo: Note that the Geni OBY definition is already present, but should be updated.
- Geni-OBY-5 (updated).qxf
- (11.01 KiB) Downloaded 53 times
- Excelighting-Color-Spot-NS-530 (updated).qxf
- (11.03 KiB) Downloaded 51 times
