Re: Ubuntu 14.04 LTS Installation
Posted: Thu May 19, 2016 5:50 pm
by ahiezerCCISPS
I solve the problem, thanks.
Re: [SOLVED] Ubuntu 14.04 LTS Installation
Posted: Fri May 20, 2016 6:07 am
by plugz
Did the update solve the problem, or did you find another solution ?
Please say how the problem was fixed so others with the same issue will know how to fix it.
Thank you.
Posted: Fri May 20, 2016 2:31 pm
by ahiezerCCISPS
I just Update the Software.
Posted: Mon Jul 25, 2016 1:19 am
by keithsplace
Thought this update and upgrade tip might be my problem as well, but to no avail. Trying to install QLC+ 4.10.4 or 4.10.3 on Linux Mint 18 x32 on older i386 IBM Netvista.
It does everything else really well.
I have installed on a newer Toshiba dual core with Linux Mint 17.3 x64 and it works fine.
Also same problem trying to install on an Acer i386 laptop, get the ERROR "Dependency is not satisfiable libudev0 (>=147)"
I tried going through the building and it's way to geeky to me, I am sort of a geek but that's over my head.
Posted: Mon Jul 25, 2016 1:24 am
by keithsplace
The PC it worked on is as follows
ISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17.3
DISTRIB_CODENAME=rosa
DISTRIB_DESCRIPTION="Linux Mint 17.3 Rosa"
NAME="Ubuntu"
VERSION="14.04.3 LTS, Trusty Tahr"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 14.04.3 LTS"
VERSION_ID="14.04"
System:
Host: Kernel: 3.19.0-32-generic x86_64 (64 bit)
Desktop: Cinnamon 2.8.8 Distro: Linux Mint 17.3 Rosa
Toshiba Satellite Laptop C655D-S5133
CPU: AMD E-240 Processor 1.5Ghz
AMD Radeon HD 6310 graphics chipset
Mem:2GB DDR3
MemTotal: 7763588 kB
Drives:120GB Corsair Force 3 SSD
major minor #blocks name
8 0 117220824 sda
8 1 109250560 sda1
8 2 1 sda2
8 5 7967744 sda5
11 0 1048575 sr0
Posted: Sat Jul 30, 2016 12:25 pm
by keithsplace
Here is the one that doesn't work.
Is it the Ubuntu 16.04 the problem? And can I change the Ubuntu version in Mint 18 and it still run?
$ cat /etc/*-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=18
DISTRIB_CODENAME=sarah
DISTRIB_DESCRIPTION="Linux Mint 18 Sarah"
NAME="Ubuntu"
VERSION="16.04 LTS (Xenial Xerus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 16.04 LTS"
VERSION_ID="16.04"
UBUNTU_CODENAME=xenial
$ lsb_release -a
No LSB modules are available.
Distributor ID: LinuxMint
Description: Linux Mint 18 Sarah
Release: 18
Codename: sarah
uname -a
Linux IBM-Netvista 4.4.0-31-generic #50-Ubuntu SMP Wed Jul 13 00:06:14 UTC 2016 i686 i686 i686 GNU/Linux
$ cat /proc/version
Linux version 4.4.0-31-generic (buildd@lgw01-58) (gcc version 5.3.1 20160413 (Ubuntu 5.3.1-14ubuntu2.1) ) #50-Ubuntu SMP Wed Jul 13 00:06:14 UTC 2016
Posted: Sat Oct 08, 2016 1:18 am
by audioasche
I am running linux mint 17 with everything updated and still get the same error.
Lenovo s10 i386 Linux mint
Posted: Sat Oct 08, 2016 1:57 pm
by audioasche
A parallel question to my previous. Does anyone have qlc+ on a Lenovo s10? If so what version of qlc and what (Linux?) Os?
Also want to add my two cents that this issue does not seemed to be solved...
Posted: Fri Oct 14, 2016 9:11 am
by audioasche
Any other thoughts or suggestions?
Posted: Mon Nov 14, 2016 7:14 pm
by GregMcC
I've been having months and months of problems ( on and off ) with this and successive versions of LinuxMint 17 and 18 - and it was really irritating me. When I read up the spec of my little Atom machine I was surprised to realise that it supported 64 bit - so I downloaded LinuxMint64 and then the QLC version for 32bit ( rather than 16bit ) and the problem went away. So check whether your machine can actually support 64 bit and then the problem goes away...
