hello guys,
How i can turn off-on a lamp when my moving heads is on.?
How to turn off-on a lamp when some moving heads are on
- Real Name: Patrick
Hello
It's depend af the DMX chanel of your moving head
could you give a link to the user manual of it
whith this i could say which chanel you must adjust for blackout lamp during the move of your fixture
Regards
Regards
- Real Name: Karolis
hi
if you set your fixture to : 10 Channel DMX Mode
you have to change the value of the chanel 9 : if you set the value between 226 and 235, the lamp will be off during the movement and : if you set the value between 236 and 245, the lamp will be off during the gobo change or the colour change .
if you set your fixture to : 12 Channel DMX Mode
you have to change the value of the chanel 11 withe the same parameters as above
I hope it's what you search
Regards
Regards
Topic renamed. Please try to give a more meaningful title next time, so searching the forums will be a bit more useful.
