I have the following problem:
I urgently need all channels being LTP, because if I call up for example a scene by button, I want the faders on the virtual desk to follow and show the result. Unfortunately either only the dimmer channels or all intensity channels ( don't know why one or the other case) are reset to HTP, when I load the setup, although I have saved it with all channels set LTP. The result is, that I can't raise any fader, which is represented on another page of the VD. Does anybody know, where and how I can make the LTP behaviour permanent?
Version is 4.10.3a Windows
test1.qxw attached as example
Thanks in advance
Peter
Where is LTP/HTP set?
- Real Name: Peter Baumgartner
No, unfortunately this is NOT the solution:
Of course I can change the behaviour here, but when I save the setup, the next time I load it, all dimmer- brightness- color-channels are set HTP again.
This is, why I asked for a permanent change!
I suspected this in the fixture editor, but there is no possibility either.
@ programmers: Is it possible, that this part is not saved by any reason????
Peter
Peter
Hi, I tried that too: made a workspace, added four dimmers, changed all but the third from HTP to LTP, saved it, quit QLC.
Loaded the workspace again - all dimmers were restored as expected...must be another issue in your settings.
Edit: I tried that with your workspace and can confirm that something weird is going on - settings are saved by random.
I think you should post it under ISSUES and let the developers jump in ....
Peter,
can you post your custom QXF files?
Hallo Jano,
here they are...
Good idea to post it in issues
Peter
here they are...
Peter
