I am using qlcplus on a debian jessie based system. I am using a DMX USB NanoDMX Interface (DMX4ALL). This interface gets detected properly. qlcplus says that the interface is ready to use ant that the libFTDI driver is used.
So I added my fixture (ignition LED PAR64 floor 20x3 W PWM RGB). But the fixture does not respond at all.
Any suggestions?
qlcplus 4.10.3a on debian jessie based system
- Real Name: Simon Schäffner
1. check your cables,
2. check your dmx address set on the fixture,
3. try with simple desk
4. try with another fixture
If none of these steps solve your problem, there's most likely a problem with your dmx interface. If you have any windows based pc around, maybe try with that.
Simon
Simon
Looks like the udev rules are not applied.
Or probably your user must be added to the 'dialout' group.
Check groups until works
Check groups until
echo "foo" > /dev/ttyUSB0
