better_text rgb script help
Posted: Tue Apr 26, 2016 7:28 pm
by prutseltje
Hi all,
I have been building a better_text rgb script. This is the initial test and I have some issues with the intergration with QLC+
The project can be found on : https://github.com/prutseltje/qlcplus-better-text
In the devtool I can see the plugin, But when I copy it to my QLC+ installation, there is no better_text :(
I've tested with an other script and changed the name, this works fine.
Who can help me with this issue?
Kind regards,
Rob Nieuwenhuizen
Re: better_text rgb script help
Posted: Tue Apr 26, 2016 9:03 pm
What OS?
In linux copy the file to ~/.qlcplus/rgbscripts
http://www.qlcplus.org/docs/questionsan ... ser-folder
I've run qlcplus -d 0 and in the log qlc+ diplayed parsing errors for the script. I created a PR for you.
It seems that orientation and size doesn't affect the output (yet?)
Posted: Thu Apr 28, 2016 3:53 pm
by prutseltje
You gave me the solution via github, char is a reserved keyword. Now the script shows in QLC+
After running QLC+ in a Linux virtualbox I saw the issue in the debug log.
The next step is to get the input via QLC+ working.
After that the orientation, and offset.
