Hi, I'm looking for Chauvet Kinta FX fixture file?
If anyone already have, please can you share.
Chauvet Kinta FX
- pipolino419
- Real Name: Rodolfo
Please read Pipolino's post above and act accordingly. It's not that hard.
Thanks for cooperation.
- Real Name: mark k
can someone please make a file for the kinta fx I am new to this dmx stuff this is the only light that I don't have a file for now .. thanks to whoever takes the time to make it I appreciate it ...
https://www.chauvetdj.com/wp-content/up ... 5_WO-1.pdf
- Real Name: Mark Lohrey
Give this one ago
- Chauvet-Kinta-FX.qxf
- First attempt
- (6.17 KiB) Downloaded 123 times
- Real Name: Scott Russell
Hey mlohrey - thanks for the fixture definition! Everything seems to be working well except for the laser section. The colors are correct but I can't seem to get them to do much more than a static pattern that blinks when the rotation is changed. Let me know if this is a definition problem or if I have a setting wrong from my end (I'm very new to QLC+). Thanks again!
I have followed the manual accurately, I believe.
I am not familiar with laser type devices but sometimes programs or macros on one channel can affect other channels. Lighting manuals, in my experience anyway, are notorious for lack of detail!
Also, when working with all the DMX controls as in 9-ch mode, you have the control over each item and may have to build the efx you want from within QLC+.
If you want to test the device independently of the fixture definition, then just give the light an address, say 001, and then go into simple desk and use the sliders (1 to 9 if the address is 001 and you are in 9-CH mode) to check what the light does over each address range.
Cheers
Mark
Cheers
Mark
HI - not sure if this ever got solved. I downloaded the QFX file posted earlier and it only has 8 channels defined instead of 9. It was missing the laser strobe channel (8) and the rotation was on ch 8 instead of 9. Attached is my corrected version I made so I can manually control the lasers. I've also added slightly more descriptive titles to stuff cuz the manual is not entirely clear s to what channels control what e.g. Colour LEDs vs White strobe LEDS.
I attached a "-z" to the fixture name so you can tell it difference form the original file, but that is easy to change to whatever you want in the fixture editor.
Separate issue: When I put this file in the (Windows) User\username\\QLC+\Fixtures, then QLC+ does not find it in the fixtures list so I could use it. I had to manually place it in the main program fixtures directory to get it "registered" i.e. in C:\QLC+\Fixtures.
My apologies if this was previously fixed and I didn't see it.
- Chauvet-Kinta-FX-zapdogster.qxf
- (6.45 KiB) Downloaded 97 times
- Real Name: Lukas
Hey, thanks for the corrections!
I would like to submit this fixture definition for adding it to QLC+, but unfortunately, the max PAN value is missing. Could you please find it out or give a rough estimation? Or is it a fixture with endless PAN?
Regards,
Regards,
