Problem with Victory II 250
I think what David meant is "what the hell are these "commands" you're talking about ??"
- Real Name: David
- What is your DMX interface ?
- What exactly have you tried ?
- Have you tried with only the victory II connected ?
- Have you tried with another cable ?
- Have you tried with a DMX terminator ?
- Are you SURE the address is configured correctly ? Have you tried with address 1 ?
- Have you tried with another DMX interface ?
Stefano, please try to be a little bit more cooperative as we cannot understand what you're doing if you don't provide the necessary details.
Keep on saying "it doesn't work" "it doesn't move" "it doesn't light", doesn't bring any contribution to this thread.
Please do this:
- set the Victory to DMX address 1
- connect it alone to the DMX cable (and no other fixtures)
- open QLC+ , go to simple desk and move manually some channels
Then please come back with the results.
[P.S.] Topic moved into the presumed category
Please do this:
Please define "generic Usb Dmx interface"Sbs wrote:I have a generic Usb Dmx interface but with Protocol Enttec ... with other heads it works fine ...
If you're using one of those crappy chinese adapter bought on ebay for $10, then you might have your answer. Probably the Victory is more sensitive than your other heads to a precise DMX signal
