QLC + unexpectedly shutting down
- Real Name: darrin pinegar
I have been having some issues with QLC + unexpectedly shutting down since updating to build 4.10.3 I’m using a MacBook Pro with OS X El Capitan version 10.11.4 and a ultraDMX RDM Pro I have never had this issue until I installed 4.10.3a Is anyone else having this issue
- Real Name: Mark Lohrey
This has also happened to me. Twice.
During an assembly, with a fairly basic lighting set up that had been running for 5 to 10 minutes, QLC+ unexpectedly quit. Lights out and a speaker in the dark. Fortunately it didn't take long to get up and going again but disconcerting.
This hasn't been an issue before 4.10.3. I haven't had a great deal of time to check out the reasons as they seemed quite random and hard to reproduce.
I have recreated the workspace for our next assembly and will test beforehand and see if it is stable.
I have attached a sample of the one that has failed.
Using Mac OSX 10.10.3 (at the time but now updating...) and an entec pro mkII
- Gym for House-Off.qxw
- (104.66 KiB) Downloaded 112 times
- Real Name: Patrick Engl
hi i have the same problem
first time QLC run without problems, after a few minutes the program shutting down.
with and without DMX interface
please help
system: Mac Book Pro EL Capitan 10.11.2
please help
Guys, are you all having crashes on OSX ?
I normally use Linux, so I need to know if this is a OSX specific issue first of all.
@mlohrey, can you recall doing something in particular before the crash occurred ? Basically: which buttons/sliders should I touch to try to reproduce ?
I understand it's not related to output devices, but what about input ? Did you have any controller plugged in ?
I just tested it on Mac QLC 4.10.2b and 4.10.3a
the problem even without a DMX interface and without midi controler.
(I also have a similar problem on windows 10 but the program not crashes.
he only stop the dmx output
dmx interface disconnect and connect again and it runs a time)
Hi Massimo,
It is very difficult to reproduce. The lights had been set and nothing had changed for at about 4 minutes and it just unexpected quit.
I will do some more testing and let you know.
We have an assembly on Friday, so I am hoping to test before then
Cheers
Mark
Cheers
Mark
Can you guys please test the TEST version here: viewtopic.php?f=12&t=3135
Please let me know if you still experience crashes
Assembly went well today. QLC+ worked perfectly. I had recreated our show file from scratch and used that, so perhaps the previous file had become corrupted. Not really sure. I will give your test file ago as well and see what happens.
I am sorry I haven't been able to find a definitive way to reproduce the error.
4.10.4 makes the same problem.
after 3 minutes only move the cursor and qlc crash.
on macbook pro OS x El Capitan 10.11.2
[EDIT] log attached
[EDIT] log attached
- qlcplus_4.10.4_crashlog.txt
- (65.11 KiB) Downloaded 108 times
Please use attachments instead of pasting huge logs.englpa wrote:4.10.4 makes the same problem.
As far as I can see, there was some function running ? If so, which one ? Do we have the project workspace to try to reproduce ?
here my file.
i hope you can help me.
- FF OGRA neu.qxw
- (133.93 KiB) Downloaded 115 times
this was my fixturesenglpa wrote:here my file.
- Antari-Z-0000.qxf
- (839 Bytes) Downloaded 111 times
- EnglPA-2R-Beam.qxf
- (10.15 KiB) Downloaded 97 times
- EnglPA-Bee-Eye-zoom-7x17.qxf
- (13.77 KiB) Downloaded 112 times
i tested on a mac book with OS X yosemaite and it works great and don't crash.
on OS X el captain qlc crash after 5 minutes.
come a new clc release in next time the was run on OS X el captain
or must i downgrade my macbook to yosemaite
thanks for infos
thanks for infos
- Real Name: Henrik Hultin
Using a Raspberry Pi 2 and upgraded to the 4.10.3 version a few weeks ago. Haven't really used it until today. It was pretty stable on older versions, but now it suddenly becomes unresponsive. The web page is inaccessible and a connected wireless DMX transmitter stops blinking, indicating that there is no DMX signal coming out of it. I don't have any monitor connected so don't know if there are any messages there.
If I reboot it will work OK for a few minutes and then freeze up again. Seems to be the same problem that others have reported in this thread???
I will check tomorrow if it is possble to downgrade to an earlier version.
Cheers,
Henrik
Cheers,
Henrik
Just tested on El Capitan (10.11.4) an no crashes whatsoever.
I also uploaded a new TEST version. Please check again with it.
I don't really understand what's your situation guys, but we need to find the detail that causes issues, otherwise I have no idea where to start to investigate this.
