Hi, please have a look at my small workspace an tell me what´s wrong with my chaser.
What I want: HPAR and MPAR changing from blue to red with a dimmer fade inbetween.
What it does: HPAR works as expected, MPAR does set the color but reset the color as soon as the chaser goes to the next step....
Both fixtures are set to LPT regaring the color an dimmer channels ... I´m desperate (
Hope someone can show me my mistake...
[SOLVED] I'm desperate - understanding chase/scene
- Real Name: Matt Weber
Set the scenes with the looks that you want, including intensity and color channels, then fade between them using the chaser. You cannot have a scene with intensity and a scene with color. The values are not held from scene to scene. Use the DMX monitor to see what is going on. You could combine scenes using the collections but you have no collection with color and intensity values set.
Please remember to mark as SOLVED a thread when you find an answer.
Please also avoid titles like the one you chose and try to give a meaningful title also for users that will search the forum in the future. Thanks.
