[SOLVED] RGB Matrix and Chauvet Freedom Par Quad-4 Fixtures
Posted: Thu Apr 14, 2016 10:03 pm
Hi everyone. I am kind of stumped. I have set up RGB matrices before this time I can't get it working. I may be trying to do something that''s not possible.
I have 20 Freedom Par Quad-4 up-lights. They are RGBA and only have one logical head each although they have 4 bulbs.
I have 10 of them addressed to one DMX channel and 10 of them to another. Then I have the two fixures in a fixture group.
So QLC only sees two fixtures but actually there are twenty.
I set up an RGB matrix with the fixture group that contains the two fixtures. I set two colors and then tested using the even-odd effect. When I see the virtual display of the lights it appears to be doing what I want.
However, when I press play and watch the DMX monitor, I see it changing the dimmer channel back and forth but I don't see it setting any color channels like I do with other fixture groups that I have rgb matrices for.
I am hoping I am missing something obvious but nothing I have tried has worked.
I created the fixture definition myself. I went back and created a 10-Channel mode and then define a single head with all 10 channels assigned to it. That seemed like the correct thing to do.
Can anyone help me figure out what I'm doing wrong? I want the even-odd effect with one set of lights one color and the other set another color around the room, switching back and forth.
Thanks,
Rob
Thanks,
Rob
