Can't assign External Input
mlohrey
Real Name: Mark Lohrey
Hi All,
I am just experimenting with using loopback to show the active state of a slider and for some reason can't assign an external input. I have tried a number of workspaces including some example ones I found in the forums.
Not sure what I have done wrong or it is a bug?
Attached is a brief movie of the situation.
Cheers
Mark
QLC+ 10.3.a
Mac OSX 10.11.3
loopback error.mp4.zip
(217.18 KiB) Downloaded 62 times
plugz
Real Name: David
You selected a universe, you did not select a channel.
mlohrey
Thanks for the help, plugz
I thought I doing something wrong.
I had tried adding a channel number but it didn't work. I have since discovered you have to be quite careful when you add the channel number.
I had clicked off the line that has the channel number and that is when the trouble started!
I have attached another video to show the wrong way and then finally the correct way.... ;-)
correct way.mp4.zip
(822.28 KiB) Downloaded 69 times
plugz
Real Name: David
tip: You can create an Input Profile for this universe in the Input/Output tab, after this the channel selection may be easier.
