Mac OSX Segmentation fault: 11
Posted: Mon Apr 04, 2016 1:58 am
by ianjamespiano
Hi Everyone! Very new but excited about QLC+ thank u!!
Mac OSX 10.11.3
When connecting remotely through the Web API test page uploading my .qxw file when I tap the button in the browser window the QLC+ program quits and gets this error in terminal Segmentation fault: 11
Thanks For any help!!
IanTestWeb.qxw
(2.38 KiB) Downloaded 654 times
Re: Mac OSX Segmentation fault: 11
Posted: Mon Apr 04, 2016 2:11 am
by ianjamespiano
On iPhone 6 using goole chrome it crashes with the segmentation fault : 11
any ideas? thanks!
Posted: Mon Apr 04, 2016 6:07 am
by plugz
Which qlc+ version ?
Posted: Mon Apr 04, 2016 11:57 am
by ianjamespiano
Hi QLC+ version 4.10.3a
Posted: Mon Apr 04, 2016 12:15 pm
by plugz
I can't reproduce the bug on linux.
- What is the exact procedure to make QLC+ crash ? (which options do you pass to QLC+, what buttons do you click on once QLC+ is started...)
- Does OSX give you informations other than "Segmentation fault" ? Like a backtrace or something ?
Posted: Mon Apr 04, 2016 1:04 pm
by ianjamespiano
Hi again thanks for the replies!
On macbook it works fine with chrome but trying to use it on iOS iPhone the crash happens
I just have One Button Turning one light on and off (red color).
I attached what the crash log that opened up said. Thanks for the help!!
QLC+crash IOS RemotePDF.pdf
(100.71 KiB) Downloaded 552 times
Posted: Mon Apr 04, 2016 1:31 pm
by plugz
Thank you for the crash log, this helps a lot.
ianjamespiano wrote: On macbook it works fine with chrome but trying to use it on iOS iPhone the crash happens
I'm sorry but this is not sufficient. We need a lot more details.
As an example, that's what I did to test this bug:
- I start QLC+ with the -w option
- I load the workspace you uploaded here workspace
- I type localhost:9999 in the address bar of my browser to get to the web access page of QLC+
- I click on the Red Scene button on the web access page
- It works (the scene is started, there is no crash)
The order in which you did things may also be important.
Thank you.
Posted: Mon Apr 04, 2016 1:51 pm
by ianjamespiano
Hi here are the steps.
1. load Qlc+ from terminal with the -w web protocol. This opens up QlC in a New Workspace
2. Open chrome on iPhone and go to the Qlc Web Api page
3. Add the host with :9999
4. Load my IanTestWeb.qxw file from google drive
5. Back in the Mac computer the file opens but says New Workspace as the name in top bar. (This may be problem?)
6. Click on button on iPhone "Red Scene" (should I see anything in program on Mac change accordingly? I don't see anything triggering.
7. I then click on green arrow to try in Operate Mode
8. Then click Button on iPhone and now crashes after putting QlC into Operate mode.
Hope that helps?
Again, all the same steps using Chrome on MacBook work as expected and trigger the scene
Thanks a ton!
Posted: Mon Apr 04, 2016 11:04 pm
by ianjamespiano
Hello!
Using Android device with same steps things seem to work as expected. Maybe there is a bug with iOS?
Cheers!
Posted: Tue Apr 05, 2016 6:43 am
by plugz
I tried with an android device too, and another computer, and I can't reproduce the crash.
Maybe an issue with iOS chrome. I won't be able to work on this issue, sorry.
Posted: Tue Apr 05, 2016 12:27 pm
by ianjamespiano
Thanks for the replies appreciate it!
I'll just use Android to control remotely for now.
Thanks!!
I made a donation thanks for your time and help!
Posted: Tue Apr 26, 2016 11:22 am
I have reproduced this on iOS. Using Safari.
Please hold on while I try to understand what's going on
Posted: Fri Apr 29, 2016 6:56 am
I think I have fixed it.
Can you please try the TEST version here: viewtopic.php?f=12&t=3135
and let me know if the problem is solved ?
Posted: Sat May 07, 2016 5:03 pm
Can anyone please give the TEST version a try ?
