Linux DMX4ALL NanoDMX Problem
Hello, I have a problem with the NanoDMX adapter cable. The logfile says: ""DecoderMAD: can not initialize. Source file does not exist. virtual bool Na noDMX :: open (quint32, bool) "NanoDMX Interface" Initialization failed"". Does anyone have any idea why that is? HiLight (PS: I use a translator because I am not really good at English and I Speak German )
No, I have QLC+ installed with the Ubuntu Software Center.
And I have started QLC+ with this command:
That enable debug messages and store them in a log
$ qlcplus -d 0 -g
Probably same of this:
viewtopic.php?f=5&t=9670
I know your adapter is from DMX4ALL, in fact I change this thread title cause it was lacking the basic information.HiLight wrote:No, my Adapter is from DMX4ALL and i am the root .
but I had the error also , until I qlc + reinstalled.
It is similar to the Eurolite adapter because they both map to /dev/ttyACM, and believe me, I wrote the code to support it, so I know what I'm saying.
Now, more details please:
- do you see a /dev/ttyACMx device ?
- have you tried the "echo" command mentioned in the other thread ?
- what does dmesg say ?
- do you have processes trying to keep the device busy (e.g. modem manager as I mentioned in the other thread)
The more info, the more help.
-Yes, I see a device (with)
-dmesg says: [33852.960140] usb 7-1: new full-speed USB device number 11 using uhci_hcd
[33853.138324] usb 7-1: New USB device found, idVendor=03eb, idProduct=2018
[33853.138331] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[33853.138335] usb 7-1: Product: NanoDMX Interface
[33853.138338] usb 7-1: Manufacturer: DMX4ALL
[33853.141401] cdc_acm 7-1:1.0: ttyACM0: USB ACM device
-I see no other process that keep the device busy (and I can`t uninstall the ModemManager, but this is a system error and I don`t know, how to kill him )
watch 'dmesg | tail'
