Recently I bought Eurolite USB DMX512 PRO, first I tried to connect device with win 10 OS, then I discovered that it only runs with linux. So I tried with Ubuntu 14.04 64-bit device shows in Input/Output panel but when I select it I get this error:
"An error occurred while trying to open the selected device line.
This can be caused either by a wrong system configuration or an unsupported input/output mode.
Please refer to the plugins documentation to troubleshoot this.".
Thanks for your help.
[SOLVED] Linux - Eurolite USB DMX512 PRO
Hi, make sure your user have the rights to write on the device.
Typically it should be /dev/ttyACM0
you can try this from a terminal:
and see what happens.
Most likely you need to add your user to the 'dialout' group or kill the ModemManager which is an annoying service of Ubuntu blocking every "modem related" device
echo "foo" > /dev/ttyACM0
- Real Name: István Király
Here some additional infos on troubleshooting this ,,,,
Note: The dmesg linux command should display your device.
You may need udev rules to allow access.
Use your favorite editor and add a new udev rule
Allow all users access by adding these rules:
Note: add-user syntax for adding user dialout
Note: stopping modem manager
sudo mcedit /etc/udev/rules.d/50-myusb.rules
KERNEL=="ttyUSB[0-9]*",MODE="0666"
KERNEL=="ttyACM[0-9]*",MODE="0666"
sudo usermod -a -G dialout YOUR_USER
sudo systemctl stop ModemManager
sudo systemctl disable Modemmanager
