I installed the QLC+ software on a french windows 7. Unfortunatly the program installed itself in french but would like to have it run in english (easier for me). Is there a way to manually change the language to have it run in english ?
Thanks a lot !
[SOLVED] How to change QLC+ language ?
- Real Name: Lukas
Try starting QLC+ from the command line with the -l option:us272 wrote:I installed the QLC+ software on a french windows 7. Unfortunatly the program installed itself in french but would like to have it run in english (easier for me). Is there a way to manually change the language to have it run in english ?
Thanks a lot !
-l or --locale <locale> Force a locale for translation
qlcplus -l en
Please read the documentation
http://www.qlcplus.org/docs/commandlineparameters.html
- Real Name: Kevin Roth
Assuming you were in the correct directory, you likely have to put "./" in front of the command. I.e.: "./qlcplus -l en"
