I'm afraid I need to say that this is not a happy ending story...
This is the device I'm going to talk about (link to the device page)
After a few feedbacks from users trying to use it with QLC+ (without success), I decided to buy one.
I have always been skeptical that a so old device had a cost ranging around 100-120€ and recently I found it for just 68€. I thought that was a bargain and with my big surprise...I bought a kit !
Basically the box included a naked PCB and separate components, so I literally had to solder them all to assemble the device. Luckily, even with my limited soldering skills, the device worked the first time.
QLC+ always claimed to support the device on Windows, so I started from there...and after a few minutes I realized how many troubles this device brings.
To understand what I am talking about, please read this page from the OLA wiki.
Basically there are 2 revisions of the same kit (K8062) and the first revision was definitely not suitable for a reliable DMX transmission (512 channels @ 44Hz)
Now the troubles:
- first of all there is no way for QLC+ to understand the revision of the Velleman device
- the above is caused by a very bad design of the Windows driver. Basically the K8062 is supposed to be a HID interface, but it's not. It uses two software components to work: a DLL file (K8062D.dll) which is the QLC+ interface, and a binary exe file (K8062e.exe) where Velleman stores all the big secrets to communicate with the hardware.
Unfortunately the exe file is close source and I don't have the sources of the DLL file either.
Basically the exe file is a daemon that is started when the DLL requests to communicate with the device. In fact, when you activate the DMX output in QLC+, you will see something flashing on the screen for a fraction of second. That's the exe file starting up and as far as I understood, it implements some DMA transfers, most likely through another DLL called FASTTime32.dll.
- when you plug a K8062 on Windows for the first time, all the above 3 things are automatically installed in your system (2 DLLs and the EXE). Problem is that Windows developers think that the whole world use Microsoft tools to develop, and this is not the QLC+ case (I use MSYS2) so QLC+ is not compatible with the DLL provided by Windows out of the box. That's why if you intend to use a K8062 with QLC+, you need to copy a modified version of K8062D.dll to the main QLC+ folder
- furthermore, starting/stopping the device is very unstable. Sometimes the EXE daemon gets stuck and you might find 2 instances of it running at the same time, which means the device will not work
Conclusions:
- in general, my personal suggestion is: stay away from this device
- if you bought the K8062 many years ago, it's not guaranteed to work with QLC+
- after some tweaks, I restored the support of the adapter in QLC+ 4.10.3 (screenshot below), but I'm not quite happy about it
- Linux/OSX support would be possible, but after seeing how badly the device works, I'm not convinced that the effort it worth it
- for the same price, you can find much better DMX adapters, fully supported by QLC+ and where the manufacturers are more open to the open source world
The Velleman K8062 story
- k8062_shot.png (9.17 KiB) Viewed 29217 times
- Real Name: Gilbert Vaillancourt
I just bought a Velleman VM116 (wich is a already assembled K8062). I bought this device because QLC+ documentation had this device listed as fully compatible. Yet I discover that this is not the case after reading this blog. Now you are talking about a modified K8062.dll file that is available but I get a 404 error.
I'm kind of disapointed about spending money on a product that QLC+ says is compatible when it is not !
I have four questions.
1. Is this modified DLL will work properly ?
2. Where can I find this modified DLL ?
3. Why is there still information about this device on QLC+ site if the device is not compatible.
4. Which device do you suggest is fully compatible and not astronomically expensive.
Regards
Regards
Sorry, back in January there's been a website hosting migration, so the ZIP file got lost for some reason.
I've restored it back now.
In general though, before buying a device, one should do a research about how well it is supported.
Among all the possible solutions, you picked the most outdated and less supported by QLC+.
Hi Massimo,
Thanks for your help. I will make some testing and keep you posted on my results.
Meanwhile I have search for a replacement device in case the Vellemenan does not do the job.
I don't want to pay a fortune for this but I have found two models that are not too expensive.
Wich one would be the best buy for me.
A. GUS Electronics USB-VL344
B. ENTEC Open DMX USB
Furthermore I intend to put some presure to get more ouverture from them.
Can you tell me exactly what you need from them in order to solve the problem with Velleman device.
Regards
Regards
Velleman says that their product is Open Source and supplied me with all the sources.
I don't know if it would be usefull to you. If so let me know.
Furtheremore I did some test using the modified DLL. Unfortunately QLC+ crashes everytime I try to change a fixture control value.
Regards
Gilbert
Regards
Gilbert
I hardly believe that.Velleman says that their product is Open Source and supplied me with all the sources.
While sources are available for the DLL interface, there is a big black box called K8062e.exe of which they don't provide the source code.
If they do (and this has to be something happened after this blog post, because I've definitely searched for it), please ask them where I can download them.
http://www.velleman.eu/downloads/files/ ... source.zip contains sources to both the dll and exe file, although it's in pascal...
Hi Massimo,
I understand that it might take a while before the situation with the Velleman VM116 device is solved,
but right now I some some important gigs coming up soon and I looking for an alternative.
I have found two devices that are not too expensive.
Wich one would you suggest.
Or any other model that you would recommand so I can go on with my project.
Regards
Regards
Well you want to perform "important gigs" opting for the cheapest adapters on the market. (seems like a common idea in this forum, not just yours)
"Open DMX" adapters are suitable for a party with friends, not for a professional service. Search this forum for "open dmx" and see what happens with those adapters.
I normaly would say "go for a PRO device", but if I really have to decide (gun on my head), I'd say Enttec Open might be it.
Don't tell me I haven't warned you
If you want the most stable and most compatible, choose enttec open dmx ethernet or dmxking edmx or similar artnet/sacn node. Tcp/ip drivers are in all systems, and you can even use cat5 cables or wifi if needed. Buy once cry once
- Real Name: sam sandy
Very nice and thanks for the post.
Hi Massimo,
Since I had a bad experience with Open DMX once I think that I don't want to have another one. If I go with Entec DMX USB Pro do you think I will avoid all the hoorors I read about OPEN DMX ?
Regards
Regards
Hi All,
It's been quite a while since I had this adventure with the Velleman VM116 device.
Looking at available and affordable DMX interfaces I came across a small but effective DMX interface
called KMTronic. This ting installed like a charm and works like a charm. Did over 50 gig since then,
used it for all kind of situations and it ran with consistancy every single time. Best part of it, I paid
less for this device than for the VM-116. Finally I was able to sell the VM-116 to someone who use
FreeStyler. I lost a bit but not too much.
Regards
Gilbert
Regards
Gilbert
A tip for all users who wanted to use this fixture anyway :
- Setup Freestyler DMX
- Launch Art-Net to DMX application (provided with Freestyler)
- Setup QLC+ to work with Art-Net on that node.
It works !
For small installation, it could be a priceless issue.
It works !
