Beamz MHL90 - Moving Head LED RGBAW-UV
DJ MoreBass
Real Name: Hans Erik Tjelum
This is the MHL90 Moving Head Wash LED RGBAW-UV from tronios (Beamz)
Both 15-ch. and 11-ch. modes has been testet.
Product:
http://www.tronios.com/en/lighting/movi ... led-s.html
Manual:
http://files.tronios.com/Manuals/150.530|Manual.pdf
Beamz-HML90-Wash-5x18W-RGBAW-UV---Moving-Head.qxf
(5.28 KiB) Downloaded 107 times
added, thanks
The file name and the product name were wrong though...it's MHL, not HML !
BjornRoesbeke
Real Name: Bjorn Roesbeke
Specifications
  • High power 5x 18W 6-in-1 LEDs
  • RGBAW-UV colour mixing
  • 11 or 15 Channel DMX mode
  • Adjustable Pan/Tilt speed
  • Adjustable strobe speed
  • 0-100% Dimmer
  • DMX and Stand-alone mode
  • Master/Slave function
  • Control panel with LED display
  • DMX in/output via 3-pin XLR
  • 540° pan, 180° tilt
The web links for this fixture are now leading to a 404 error page. It's been moved to BeamZ lighting .com.
There's no direct link to the manual on the BeamZ lighting website that i could find, so i've put a copy of the MHL90 manual on my own website. There's also an extract of the channel info available.
Respond or send a PM if any of my fixture definitions contains errors.
