Issue with xy pad and speeddial
rudi
Real Name: Rudi Donné
I've noticed that the effects speed in xy pad is not real time affected by speeddial in VC.
You have to switch between effects to change the speed of the effect. I think this is not the way things should work. Is there a solution or workaround for this problem?
Platform Win10. Latest QLC version. Workspace attachted.
Regards,
Rudi
speeddial-xypad.qxw
(7.05 KiB) Downloaded 96 times
janosvitok
Real Name: Jano Svitok
There is a problem indeed. For now, create normal buttons (possibly in solo frame) to start the effects. That way they will react to speed change.
Confirmed: XYPad do not react to speed change from speed dial. Also the preview does not react to speed change at all.
rudi
Thanks Jano,
I always used solo buttons but to clean up my VC I started to use the xy-pad.
Back to the solo buttons... maybe there comes a solution for this soon.
For the animation widget speed dial works well.
Regards,
Rudi
plugz
Real Name: David
working on it...
plugz wrote:working on it...
If the issue is confirmed, can we add an issue to gitHub so this doesn't get lost in the forum torrents ?
rudi
Hi plugz,
Any news about this?
diju
Real Name: Dirk J
Hello * !!!
This issue still exists and i would also appreciate to have this speed update functionality.
In addition: The *clear all* (X) Button doesnt clear the activated effect on all xy-Pad!?! This is not intended, isn't it?
rudi
I don't know what you want to say. See my attached workspace. XY pad does not response to Speeddial taps or adjustments.
This issue was reported over a year ago.
Regards,
Rudi
speeddial-xypad.qxw
(4.73 KiB) Downloaded 59 times
rudi
Jano,
Already 480 views on this topic... I think it's time to take this isssue in consideration maybe.
Are you still having this issue? I tried to reproduce it using the latest sources and your provided workspace and I wasn't able to see it.
