QLC+ 4.10.3 from GIT on Xbuntu 15.10. The crash occurs when click on New Audio in function manager, the file manager window does not appear crash immediately. Adding other functions scenes, chasers and video works well. Opening a workspace with audio files loads well and I can play audio.
virtual void FunctionManager::showEvent(QShowEvent*)
virtual void HPMPrivate::run() La crida al sistema ha estat interrompuda
DecoderMAD: cannot initialize. Source file doesn't exist.
Violació de segment (bolcat de la imatge del nucli)
QLC+ GIT - crash adding audio files
- sbenejam
I've done a major change to the audio decoder system on GIT.
You better distclean your sources and build from scratch.
That might solve the crash
- sbenejam
Hi Massimo,
Don't work, first I made a make distclean and ./create-deb.sh purged qlcplus and install the new package, qlcplus crash.
I deleted qlcplus folder and cloned from GIT. Same result
OK, try now
P.S. moved in the development forum
- sbenejam
Now works well, not crashing opening add audio file manager.
