I come back with a new topic on the tab order in the function editor.
Each time I load a workspace after opening QLC+ the order of the fixtures change and the tab are not sequential form 1 to 8 (in may case 8 fixtures).
It is random, no rule seems to be emerging.
QLC+ 4.10.3 TEST
[FIXED] Tabs order in scene editor
- basic.qxw
- (27.59 KiB) Downloaded 84 times
Enttec DMX USB Pro
Windows 10
Windows 10
It would be great to have the possibility to change the tab order manually (and "save" it) in the scene/function editor.
Also when I switch from "tab viev" to "all channels view", it would be great to arrange the order of the fixtures.
Regards
Pacco
Regards
Pacco
Now fixed on GIT
If you mean 4.10.4 GIT than it still doesn´t work for me:Now fixed on GIT
- create a scene
- add 5 generic fixtures ... the are ordered #1 thru #5
- create another scene
- go just back to the first scene ... order is scrambled: #4, #3, #2, #1, #5
I mean it is fixed in the current GIT sources.yokosuna wrote:If you mean 4.10.4 GIT than it still doesn´t work for meNow fixed on GIT
I just tested what you've written above and it works for me.
You haven't written where "4.10.4 GIT" comes from (OBS ? built yourself ? where ?), so most likely you're testing the wrong GIT version
I went to this topic: viewtopic.php?f=12&t=3135
and this file: http://www.qlcplus.org/downloads/test/Q ... 160419.exe
- Real Name: David
This version is from 2016-04-19. The fix was made on 2016-04-25.yokosuna wrote: I went to this topic: viewtopic.php?f=12&t=3135
Push what ?
If no new windows build is available, it means nobody has time or the chance to do it.
