Hi guys
I have a problem with the OSC configuration, TouchOSC recive a feedback data from Qlc+ (if i move a slider on qlc its move correctly on the app) but if i move the touch slider on the app nothing happens in Qlc+.
Some information about my network and configuration:
QLC+
IP: 192.168.1.107
Incoming port: 7700
outgoing port: 9000
trasmission IP: 192.168.1.112
Plugin flag on input and feedback
Custom layout of touchOSC correctly inserted and pached on virtual console
TouchOSC IP: 192.168.1.112
Host: 192.168.1.107
Incoming port: 9000
Outgoing port: 7700
ZeroConf: Blank
Thanks for helping me
[SOLVED] OSC problem
- Real Name: Matteo Portaluppi
Please attach your qxw file.
If i don't use a profile the OSC work normaly now, if i select my custom profile (make with autoreconition) nothing response apart the feedback
- Real Name: Mikee
I am having the same issue, was a solution found yet? I am using the newest version 4.10.1
- Real Name: George Pierson
My Apologies if this is an obvious thing, but I had trouble with this due to my Firewall blocking certain ports, following this, the ports were reserved for other utilities in the demo room. Worth checking in case you have a clash there.
- Real Name: Mikee
Works now THANKS! Im still having an issue getting communication with Resolute VJ program. So that if i make a Button in QLC that controls something in Resolute.
