I apologise in advance if this is a stupid question, but is there a main UI file for QLC+ or is the UI coded manually? I am aware there are separate UI files for each widget, such as the chase editor, but have failed to find a main UI (as in MainWindow.ui or something?).
Main UI
The UI is coded manually. Are you looking for something specific?
- Real Name: Cooper Beutel
Thanks. I was looking for the main UI only, but since it is coded manually, there won't be any specific UI file, other than those in the UI folder (chaser editor, etc.)
My question was more what do you want to do with the UI file?
Sorry, my apologies.
I have been given the task of customising the appearance of QLC+ in terms of modifying the colour scheme and icons. However upon further research, I do believe that the customisation options for the virtual console will suit my requirements.
I asked first though because I thought it may have been a simple UI designer file that I could 'tinker' with.
Thanks anyway!
Thanks anyway!
Read the documentation:
http://www.qlcplus.org/docs/guicustomstyles.html
You can't customize the icons though, as they are embedded in the QLC+ UI binary.
Unless, of course, you build from sources.
