Hey guys I am a DJ and looking for this software to become my main software.
Setup:
AKAI APC Mini Control Interface
DMX output ARTNET
I will do my best to explain what i am doing if anyone wants to see my show file I can Share that with you.
Fixtures list (Currently)
DMX CH Fixture CHANNEL LIST
1-4 ADJ DJ SCAN 250 PAN,TILT,COLOR WHEEL, GOBO
5-8 ADJ DJ SCAN 250 PAN, TILT, COLOR WHEEL, GOBO
9-11 CHAUVET MEGA TRIX PATTERN, SPEED, STROBE
12-14 CHAUVET MEGA TRIX PATTERN, SPEED, STROBE
15-21 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
22-28 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
39-35 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
36-42 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
43-49 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
50-56 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
57-63 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
64-70 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
71-77 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
78-84 STAGE APE HAMPSTER GREEN, RED, BLUE, COLOR MACRO, COLOR SPEED, STROBE, DIMMER
Issue:
In Virtual Console I have a Multi Page Frame (Fixture groups: DJ Scan's, Mega Trix, Hampsters)
Then within that frame I have a Multi Page Sub Frame (Fixtures Paired, Left Fixture, Right Fixture)
Within each of the sub frame's I have a Button Matrix 8x8 and a 9 Slider Matrix.
I am controlling the fixtures single Channels on each slider. (IE Slider1 = Both Scanner Pan's Slider2 = Both Tilt Channels) and so on for each fixture group.
But I am getting bleed (One or two fixtures react when their page isn't active. Is there a way to eliminate that?
This is very frustrating to be trying to setup pages of fixtures without having the ability to group things up cleanly.
Miss Behaving DMX Controls
Please post your qxw file.
Note also that controls on non-visible pages are still active - so before switching pages you have to pull sliders to 0.
- Real Name: Michael Chilson
I don't like that. And that actually doesn't seem to be the case most of the time.
I switch pages and move the faders and most things behave I just have a light or two that just doesn't want to be good.
I can go between main pages and sub pages without issues adjusting faders and only the active pages change. (Other than the couple of problem childern)
FYI i have been tinkering with this file so all the sliders now might not do anything. I'll upload the updated one with everything thing re-linked tomorrow. But this should let you see whats going on.
I also am running Easy View 3D visualizer to see the DMX issues.
Correct me if I'm wrong but I believe the Elation MidiCon functions this way. I believe up to 24 pages with motorized faders. now granted mine don't move and the minute I move the fader the on screen fader jumps to where the hardware is but thats ok.
I have also Attached all the Fixture Profiles (Some have not been used yet)
- Mike C-LEDSplash-Jr.qxf
- (1.63 KiB) Downloaded 99 times
- American-DJ-DJ-SCAN-250.qxf
- (3.29 KiB) Downloaded 98 times
- DJ Show 1.qxw
- (503.17 KiB) Downloaded 125 times
