Light-Visualisation with Blender
I found a bit of code implementing a simple Art-Net Node for the Blender Game-Engine. So, i started playing and here is a simple demonstarion how to visualize a lightshow with Blender. Just start the Stage.blend with the blenderplayer and use the Stage.qxw to control the lights. Im using Blender V2.72b and QLC+ V4.10.1 on Debian. (You can move the figure by using the cursor-keys)
- Stage.blend.zip
- (1.11 MiB) Downloaded 263 times
- Stage.qxw
- (26.26 KiB) Downloaded 228 times
I played again and here is another File. In this file, the artnet-node and the fixures are separated. it contains 3 full animated moving heads with configurable start-address (Select HVec* and set the property "channel"). every head has pan, tilt, dimmer, red, green and blue channels.
- MH.blend.zip
- (124.65 KiB) Downloaded 224 times
- Real Name: Bryan Crotaz
