XML namespace changed to www.qlcplus.org
cingulingu
Real Name: Veljko Stankov
Found a glitch. In update-fixture-map.rb
I don't know what happened. Yesterday, morning it worked as usual. But now it give me this.
./update-fixture-map.rb:239:in `load': undefined method `content' for nil:NilClass (NoMethodError)
        from ./update-fixture-map.rb:210:in `initialize'
        from ./update-fixture-map.rb:258:in `new'
        from ./update-fixture-map.rb:258:in `block (2 levels) in load_fixtures'
        from ./update-fixture-map.rb:257:in `glob'
        from ./update-fixture-map.rb:257:in `block in load_fixtures'
        from ./update-fixture-map.rb:256:in `chdir'
        from ./update-fixture-map.rb:256:in `load_fixtures'
        from ./update-fixture-map.rb:479:in `<main>'
There was no changes in ruby or ruby-xml.
cingulingu wrote:Found a glitch. In update-fixture-map.rb
We haven't touched that script (last change was 5 months ago).
Probably something bad happened to your Ruby installation ?
janosvitok
Real Name: Jano Svitok
Fixed in https://github.com/mcallegari/qlcplus/c ... 6ac944645f
Problem was that XML namespace was changed in https://github.com/mcallegari/qlcplus/c ... 2184319f8e
I'll update all data files to the new namespace later.
Can the Ruby script handle both sourceforge and qlcplus.org namespaces ?
Otherwise, what happens if we change the URL here ?
https://github.com/mcallegari/qlcplus/b ... ap.rb#L233
https://github.com/mcallegari/qlcplus/b ... ap.rb#L274
cingulingu
Working again.. Thanks.
janosvitok
I've replaced all namespaces in data files and schemas. The script now works with the new namespace only. I wasn't able to replace namespace with libxml-ruby.
I'll do it later by bruteforce.
