Official Raspberry Pi 7" touchscreen
de DJ Fabriek
Real Name: Tiago Vilhena de Oliveira
When I edit a button I can't save changes. Can I change setting so I can use this screen?
Screen: 7"
That dialog is too large for a 7" screen.
I don't really understand why you guys insist on using the Raspberry Pi for project editing.
Can't you just do it on a PC with a larger screen and use the Pi only with the virtual console ?
de DJ Fabriek
You are certainly right. If it could have done then it is easy to make small adjustments immediately without a computer.
Thank you for your quick response.
The black border I have try to resolved.
I already tried to solve the black border, but I did not succeed. Is there a solution for this?
Most likely you need to remove the --overscan parameter from /etc/init.d/qlcplus
richbass
Real Name: Richard
Sorry if this seems very basic, but have you tried a different resolution setting in raspi-config?
This made the difference for me with my 3.5" screen
de DJ Fabriek
mcallegari wrote: Tue Nov 06, 2018 6:14 pm Most likely you need to remove the --overscan parameter from /etc/init.d/qlcplus
Thanks !
