I tested the nanoKONTROL 2 and it works very well. Congratulations again for the good work.
This a very good solution for small budget.
nanoKONTROL2 great
- Real Name: Ovidijus
Don't want to create new topic so I will ask here about this controller.
First, can't get leds to work. What I need to do that the led will stay on then button from VC is in ON mode. Now led just lights until I release button.
Second speed dial mapped to knob, but when I rotate it it dosn't move, only time changes. It's a bug? Or it shoudn't rotate?:)
ENTTEC PRO Mk2
AKAI APCmini
ENTTEC PRO Mk2
AKAI APCmini
- sbenejam
You could use the Korg Kontrol Editor configuration software to set the LED MODE to EXTERNAL to get the leds working. The Nanokontrol2 LED MODE is set to INTERNAL by default.Ovis wrote:Don't want to create new topic so I will ask here about this controller.
- mumbles
- Real Name: Justin
I didn't realize you could change led mode. I thought it was a limitation with QLC+. Ill have to try this. If it works that's going to make everything more intuitive and nice! I assume this is possible with the nanoPad2 also? Thanks for the tip!sbenejam wrote:You could use the Korg Kontrol Editor configuration software to set the LED MODE to EXTERNAL to get the leds working. The Nanokontrol2 LED MODE is set to INTERNAL by default.
OSX 10.10.5 QLC+ 4.9.1
Surface Pro4 Windows 10
Raspberry Pi B OLA 0.95
Raspberry Pi 2B QLC+
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
FTDI USB-RS485-WE-1800-BT XLR
Korg nanoKONTROL2
Korg nanoPAD2
Swisson XMt-350
Chauvet RDM2Go
Enttec Pro Mk2
ultraDMX Micro
Korg nanoKONTROL2
Korg nanoPAD2
- nedmech
- Real Name: Nathan Durnan
Jumping in on this topic... Has anyone gotten the Marker Set button LED to work on the NanoKontrol 2? The button input works just fine, but I've never seen it light up with the feedback from QLC. Every other button's LED seems to work just fine though.
Where do I find the “LED MODE” to VCH Anne it to external?sbenejam wrote: ↑Thu Oct 22, 2015 6:42 pmYou could use the Korg Kontrol Editor configuration software to set the LED MODE to EXTERNAL to get the leds working. The Nanokontrol2 LED MODE is set to INTERNAL by default.Ovis wrote:Don't want to create new topic so I will ask here about this controller.
- sbenejam
Donwload Korg NanoKontrol/Korg Kontrol Editor connect your NanoKontrol2 reconfigure and save.
http://www.korg.com/us/support/download/product/0/159/
